Ansys Learning Forum Forums Installation and Licensing Ansys Products Ansys Workbench Error while starting: Connection timed out while reading data. Reply To: Ansys Workbench Error while starting: Connection timed out while reading data.
mkhademi
Hi Karri,
I did what was suggested by the Ansys employee to others as below. However, the workbench is just showing the starting window and nothing appears even after 10 minutes. Can you confirm that this works when the license is on a server? Who must add these syntax, the client or the administrator on server machine?
Please try adding these entries to your C:\Program Files\Ansys Inc\Shared Files\Licensing\ansyslmd.ini file.
ANSYSLI_FNP_IP_ENV=1
ANSYSLI_TIMEOUT_FLEXLM=20
ANSYSLI_FLEXLM_TIMEOUT_ENV=20000000
ANSYSCL_TIMEOUT_CONNECT=60
ANSYSCL_TIMEOUT_RESPONSE=300
