Ansys Learning Forum › Forums › Discuss Simulation › 3D Design › Geometry is messed up when opening file received from someone else › Reply To: Geometry is messed up when opening file received from someone else
August 16, 2024 at 1:26 pm
Atharv Joshi
Hi Rhandy,
Can you please try changing the rendering settings? Use higher value of rendering and recalculate rendering.
Check if there are geometry error from the Measure Tab > Check Geometry. You can use tools from repair tab to fix the issues in the geometry.
Try importing a step/iges files and check the behavior.
Thanks and Regards
Atharv
