Ansys Products
Ansys Products
Sbatch fluent
    • blanca.cerda
      I am trying to run fluent by commands.
      Using the interactive window is something like:
      srun fluent -r23.2.0 2ddp -g -t20 -case
      /solve/dual-time-iterate
      /file/write-case-data
      /exit/close-fluent
      This works really good, then i can read the results and everything works well.
      But trying the same commands through an sbatch file shows me the error after running the case and the data, considering the commands like a directory.
      The sbatch looks something like this because is how the cluster works.
      #!/bin/bash
      #---------------Script SBATCH ----------------
      #SBATCH -J Simulacion
      #SBATCH -p general
      #SBATCH -n 1
      #SBATCH -c 20
      #SBATCH --mem-per-cpu=1000
      #SBATCH --mail-user=mail@mail.com
      #SBATCH --mail-type=ALL
      #SBATCH -o Simulacion152040_%j.err.out
      #SBATCH -e Simulacion152040_%j.err.out
      #-----------------Toolchain---------------------------
      ml purge
      ml intel/2022.00
      # ----------------Modulos----------------------------
      ml  ANSYS/2023R2
      # ----------------Comando--------------------------
      export OMP_PLACES=cores
      /exit/close-fluent
      Running this, i got:
      Is there a way from fluent to do all this properly?
      Thanks in advance
      Looks like the Slurm script is trying to action the Fluent commands rather than them being used in Fluent. I'd favour launching Fluent with a journal, so the command launches Fluent with a journal which contains the read case & data, run, write case & data, exit.  The Fluent part is covered in the User's Guide,  https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v242/en/flu_ug/flu_gs_starting.html   The Slurm part is likely something your IT people control.
    • blanca.cerda
      Hello dear,
      I tried using a journal file, that i created as a text file, Thanks for the advice.
      It works
