Ansys Learning Forum Forums Discuss Simulation General Mechanical Workbench Mesh Offset Related Question Reply To: Workbench Mesh Offset Related Question
mjmiddle
When I tested this in Ansys 2024 R2, it only showed an offset with "Thick Shells amd Beams" on. What version are you using?
Your latest picture appears to show solid geometry in the geometry modeler, not the "Thick Shells amd Beams" which is only going to apply when mesh is displayed.
