Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Using the Quality Factor Analysis Group › Reply To: Using the Quality Factor Analysis Group
August 1, 2024 at 3:30 am
Hello! Thanks for the question, and it was great that you provided the link. I was able to check the file you are referencing.
I believe the issue is due to the fact that you need to change the minimum and maximum wavelength settings for the DFT Monitor. This monitor supplies data used by the Qanalysis group. In order to measure the resonance between 300 and 700 nm, you can make this change:
Let us know if this doesn't do the trick for your simulation.
