July 28, 2024 at 11:45 pm
Zwernjayden
SubscriberThe fmean residual falls to around 1e-20 over the course of around 15 iterations, and then fluent crashes with this error. I am using DPM and non pre-mixed combustion. I tried the same setup with the EDC combustion model and I didn't get the error, but would rather use non pre-mixed combustion model
July 29, 2024 at 4:52 pm
Forum ModeratorHow much evaporation did you see before the solver failed? How does the combustion mechanism differ between the two models: ie what core assumption is different that could explain the problem?
- The topic ‘SIGSEGV error and fmean residual’ is closed to new replies.
1565
1386
1242
