Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Fatigue Analysis and Test Validation › Reply To: Fatigue Analysis and Test Validation
July 26, 2024 at 1:39 pm
danielshaw
No. Fatigue results are hard to "prove", because there is wide variation in the test results. You will never be able to correleate a fatigue simulation result with single test result. You need to have a statistically significant set of tests and confirm that the simulation result is within the range of test results.
