Ansys Free Student Software
Electronics Desktop 2019R2 break down when I check the Rmxprt model
    • NaplonDennis
      I created an Rmxprt model, and when I checked it, the following menu popped up. Can anyone help me figure it out?An error prompt
    • tsiriaks
      do you get the same issue if you use the sample projects that come with the AnsysEM installation (File -> Open Examples -> RMxprt) ?
    • NaplonDennis
      yes, it happens
    • tsiriaks
      what if you try other design type like HFSS, Maxwell 2D , etc. ?
      you can try renaming your C:UsersusernameDocumentsAnsoft   folder to anything else
      also try setting your temp directory to be under C:Temp . You can change this from AEDT GUI -> Tools -> Options -> General Options -> Directories
      If these don't help, I suspect issue is related to graphics.
  • The topic ‘Electronics Desktop 2019R2 break down when I check the Rmxprt model’ is closed to new replies.
