Ansys Learning Forum › Forums › Discuss Simulation › 3D Design › ansys discovery initial temperature › Reply To: ansys discovery initial temperature
July 15, 2024 at 12:55 pm
Hello Arden,Â
That initial temperature is default for the faces which does not have any condition defined. If you want to set different temperature on to specific face use the Temperature BCs from thermal conditions as shown below:
Similarly for fluid inlet faces you can define the temperature for fluids.Â
Devendra
