July 14, 2024 at 9:36 pm
wissem chakchouk
SubscriberI want to do a coupling acoustic structure coupling in ls dyna but is not worked.
I used Boundary_Acoustic_Coupling also Boundary_Acoustic_Coupling_MISMATECH but not worked do you have any idea what is missing ???
July 15, 2024 at 11:20 pm
Ushnish Basu
Ansys EmployeeWe cannot comment on specific issues with your model, but I would suggest that you look at the descriptions under BOUNDARY_ACOUSTIC_COUPLING, and in Appendix W in the manual.
July 16, 2024 at 9:05 pm
wissem chakchouk
SubscriberHello**** I want to do a coupling between the part blue which is a structure meduim and the red part which is the fluid meduim which we supposed our acoustic meduim. I used BOUNDARY_ACOUSTIC_COUPLING also Boundary_Acoustic_Coupling_MISMATECH I select the structure interface but it's not worked.****I want to share the nodes for these two parts (blue and red), which options I can use Contact_surface_to_surface or Contact_node_to_surface and what is the difference between them in the results.****Also, I have no idea how to change the settings of this module and what the main settings are(These settings as it shows is by default).Thank you in advance.
- The topic ‘acoustic structure coupling’ is closed to new replies.
1859
1403
1257
