TAGGED: ansys-spaceclaim, ansys-student, error, pyansys
July 10, 2024 at 6:27 am
qjaxod13
SubscriberHello,
I am using the Ansys 2024 R1 student license.
I want to generate a computational mesh using pyAnsys Geometry.
As shown in the attached image, I want to connect each line and then rotate it 360 degrees around the Z-axis.
However, when I run the code, I can only plot the sketch, and then it terminates with the following error message.
Is there a limitation in the 24R1 license that restricts the use of functions like revolve or sweep?
Thank you.
July 10, 2024 at 10:22 am
Devendra Badgujar
Forum ModeratorHello Bumjin,
You can see in the error it is poissble in 24.2 version. The APIs are new and supported with 24.2.
Revolve sweep is not available and requires minimum 24.2 version.Â
Thanks,Â
Devendra
- The topic ‘Encountering an Error with pyAnsys Geometry in Ansys 2024 R1’ is closed to new replies.
Ansys Innovation Space
1024
962
858
798
