Cyclic symmerty
    • pavan kumar
      Hello
      I am doing cyclic symmerty simulation in static structural
      below is the model
      and i defined frictional and bonded contact below is the image of model
      below image shows the boundary condition
      and loading is shown below
      i am getting the error like mentioned below
      *** ERROR ***                           CP =    8695.516   TIME= 20:49:04
       Solution not converged at time 1.666666667E-02 (load step 1 substep 1).
      can anyone  help me to slove this problem
      Thanks
    • pavan kumar
      It's very urgent requirement can anyone help me to solve this problem
      here i attached the image of analysis settings
      please have a look and do the needful
      Thanks
      Hello Pavan,
      Always insert a Contact Tool under the Connections folder and Generate Initial Contact Status whenever you have Frictional contact.
      It may be that the contact is Open and that is the cause of the failure to converge. Please show the table of Initial Contact Status.
      I suggest you first convert the Frictional contact to Bonded contact, turn off Large Deflection and try to solve. Does that work?  If so, turn Large Deflection back on and try to solve. Does that work?
      Peter
    • pavan kumar
      Hello peteroznewman
      Here is the contact status please have a look and do needful
    • pavan kumar
      Hello peteroznewman
      Yes I did this
      i changed from Frictional contact to Bonded contact, i turned off Large Deflection and this is worked without any error
    • pavan kumar
      Hello peteroznewman
      Yes i did this
      i changed this from Frictional contact to Bonded contact, i turned off Large Deflection and this is worked without any error
Viewing 5 reply threads
  • The topic ‘Cyclic symmerty’ is closed to new replies.
