Ansys Learning Forum Forums Discuss Simulation Fluids System Coupling error Reply To: System Coupling error
eunjung.chae
It is a propeller simulation, and its setup is as follows.
In the structural model,
  • material was chosen as aluminum alloy from “General Materials” in Engineering Data
  • fluid-solid interface on blade faces that have data transfer
  • fixed support at the root
In the system coupling component,
  • created data transfer for the overlapped blade faces
  • added output frequency as “All Steps”
  • then simulated by “update” the solution
