Ansys Learning Forum Forums Discuss Simulation Fluids Problem when assigning a surface from a recorded profile Reply To: Problem when assigning a surface from a recorded profile
SRP
The distortion you're experiencing when transferring data from the outlet to the inlet of a centrifugal pump wheel in your simulation could be due to several factors. It's important to ensure that the boundary conditions are set correctly and that the data is being interpreted and applied in the right manner.
