Ansys Learning Forum › Forums › Discuss Simulation › Photonics › How to create parabolic cone structure in charge lumerical. › Reply To: How to create parabolic cone structure in charge lumerical.
June 3, 2024 at 6:25 pm
Amrita Pati
Hi Sumit,
The simplest approach would have been to use custom object, however it is not supported in CHARGE. So, I believe it is not something you can even copy and paste from FDTD. If you have access to any external CAD based tool (like Solidworks), I will recommend you to create the geometry there and export it as an stl file. Then this could be imported into CHARGE. I will let you know if I find a simpler alternative.
Amrita
