Ansys Learning Forum Forums Discuss Simulation Photonics Modal analysis _finding single mode waveguide field components Reply To: Modal analysis _finding single mode waveguide field components
Amrita Pati
Hi Mijanur,
Did you compare the field compontents quantitatively? Also, what is the "waveguide TE/TM fraction" for the mode? I believe this quantity gives you an estimate of the field intensity in the propagation direction as a proportion of the total intensity.
Amrita
