Electronics
Electronics
Ansys Maxwell “mesh mapping on map” error
    • melikeoztopal
      Hi, I am a newbie in Maxwell, and I am trying to simulate a rotating circular arrangement of permanent magnets. To set up the motion, I created a segmented cylinder enclosing the wheel. However, when I run the analysis, it always gives the following error:
       "Error in mesh mapping on band, please check the potential problem in band setting.
      Simulation completed with execution error on server: Local Machine."
      Despite my efforts, I could not sort the problem out. Any help would be very much appreciated. Thank you.
    • HDLI
      Hello Melike,
             Could you add innerBand, that is smaller than Band and bigger than all the moving objects? Thanks.
      HDLI
  • The topic ‘Ansys Maxwell “mesh mapping on map” error’ is closed to new replies.
