Ansys Free Student Software
licensing error
    • Aaron Schueler
      I have tried for two months to just install ansys. On the ansys license management center, it says my license is running. However, when I open any application--workbench or fluent-- I am hit with a million licensing errors.
      I don't understand why such an expensive and good software is giving me so many issues. Please help.
    • Rajeshwari Jadhav
      Hi Aaron,
      Please use ip address of the server instead of servername in Ansys Licensing Settings.
      Launch Ansys Licensing Settings as admin> mention IP address (server 1)> test and save it> click on features in use, if any error send the screenshot.
      OR
      Can you please try the below steps to resolve this issue : (Please take help from your IT team to add the server IP entry and save the hosts file which needs admin access)
      • Open the HOSTS file on client machine and add the license server name and IP of the license server in that hosts file.
      • Path: “ C:\Windows\system32\drivers\etc\hosts file “ as per the following format in your client machine :
      • Path:  For linux you can goto etc/hosts file (root access) and at the end add entries
      Example:
      IP address                                                         Hostname of server
      xxx.xxx.xxx.xxx                                                 aschueler           //IP address of server and name add in last line of hosts file.
      • Once the entry is added save the file.
      • Launch the Ansys licensing settings and goto feature in use see if same issue occurs, if all increments are shown then launch the application.
       Let me know if this helps to resolve the issue.
  • The topic ‘licensing error’ is closed to new replies.
