Ansys Learning Forum Forums Discuss Simulation Fluids Unusual liquid velocity and bubble size distribution by using PBM Reply To: Unusual liquid velocity and bubble size distribution by using PBM
zj X
Thanks for your replying.I will try Custom Field Function.
And is there a solution to the bubble bin fraction in the head space?
I write an udf to make the aggregation rate only below the liquid surface by limiting the height, but it didn't help.There are still bubble bin fraction above the liquid surface.
I can give more information if you need.
