May 8, 2024 at 6:26 pm
Sean Langdale
SubscriberAs can be seen in the snip below, I'm trying to model a steel wall and ceiling room with a coil running through it and understand the magnetic field distribution into the room by placing a non modelled part. I'm looking to see the full field distribution in the steel, in the room and outside the room (on the non modelled square. Currently I only be able to choose one option when I go into the magnetic field - modify plot. The option to choose "All Objects" does not work and will not show me the the field across all the objects listed. Does anyone have any ideas?
May 9, 2024 at 4:08 pm
GLUO
Ansys EmployeeHi,
Please select the all object in the view, then right click them>>Fields>>Mag_B and click OK. Do not change anything in "in Volume"
GL
- The topic ‘Magnetic field distribution – Help to see the field across all options’ is closed to new replies.
