April 30, 2024 at 10:36 am
April 30, 2024 at 10:52 am
Forum ModeratorPlease can you plot the mesh surface with edges on? I suspect the difference is mesh resolution on the free surface. You can see the local refinement (adaption) on the side walls in the top image.Â
April 30, 2024 at 11:02 am
merveala01
SubscriberI opened mesh surface adaptation. In the comments, YouTuber said that there were some post process adjustments.
April 30, 2024 at 12:56 pm
Forum ModeratorPossibly, but there's a reason I asked for the mesh image.Â
April 30, 2024 at 1:38 pm
April 30, 2024 at 1:41 pm
Forum ModeratorEdges not nodes, but the surface mesh looks very coarse. Did you run on following the mesh refinement?
- The topic ‘What are the post processing tricks for water surface?’ is closed to new replies.
Ansys Innovation Space
- affinity not set
1414
1241
1118
1015
