Ansys Learning Forum › Forums › Discuss Simulation › 3D Design › SpaceClaim.API.V21.Session › Reply To: SpaceClaim.API.V21.Session
April 23, 2024 at 3:55 pm
downie
Devendra,
Below is the C++ code that we use to launch SpaceClaim and then load our Addin.
Blair
// RunSpaceClaim.cpp : main project file.
#include "stdafx.h"
using namespace System;
using namespace System::Collections::Generic;
using namespace SpaceClaim::Api::V22;
using namespace SpaceClaim::Api::V22::Extensibility;
#ifdef SimModS140
 using namespace LuaFileExec;
#else
 using namespace SC_SimScript;
#endif
Session^ GetSpaceClaimSession() {
ICollection^ SCsessions = Session::GetSessions();
for each (Session^ s in SCsessions)
return s;
return nullptr;
public ref class APICall {
public:
static String^ luaFile;
static bool addinLoaded;
static void CallAddin() {
Console::WriteLine(luaFile);
try {
LuaInterpreter^ luaInterp = AddIn::GetInstance();
if ( luaInterp != nullptr ) {
luaInterp->ProcessFile(luaFile);
addinLoaded = true;
else {
#ifdef SimModS140
Console::WriteLine(L"Unable to create SpaceClaim addin LuaExecFile");
#else
Console::WriteLine(L"Unable to create SpaceClaim addin SC_SimScript");
#endif
addinLoaded = false;
catch (...) {
#ifdef SimModS140
Console::WriteLine(L"Unhandled exception thrown by our lua interpreter LuaExecFile");
#else
Console::WriteLine(L"Unhandled exception thrown by our lua interpreter SC_SimScript");
#endif
int main(array ^args)
  Console::WriteLine(L"Executing lua file within SpaceClaim");
  Console::WriteLine(L"Current working directory is {0}",IO::Directory::GetCurrentDirectory());
String^ scdm = System::Environment::GetEnvironmentVariable("SCDM");
Console::WriteLine(L"SpaceClaim executable directory is {0}", scdm);
Api::Initialize();
Session^ session = GetSpaceClaimSession();
bool startSpaceClaim = false;
if ( session == nullptr ) {
try {
StartupOptions^ sopts = gcnew StartupOptions(30000);
sopts->ShowSplashScreen = false;
sopts->ShowApplication = false;
sopts->ManifestFile = args[0];
sopts->ExecutableFolder = scdm;
session = Session::Start(sopts);
Console::WriteLine(L"Failed to start SpaceClaim");
return 1;
startSpaceClaim = true;
catch (...) {
Console::WriteLine(L"Failed to start SpaceClaim - unhandled exception");
return 1;
Api::AttachToSession(session);
APICall::luaFile = args[1];
int result = 0;
try {
WriteBlock::ExecuteTask( "run interpreter", gcnew Task(&APICall::CallAddin));
catch (System::IO::FileNotFoundException^) {
Console::WriteLine(L"ExecuteTask failed - file not found exception");
result = 1;
if (startSpaceClaim)
session->Stop();
if (!APICall::addinLoaded)
result = 1;
Console::WriteLine(L"Done");
//Console::ReadLine();
  return result;
