Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Modeling Methane Explosion Ignition by Patch › Reply To: Modeling Methane Explosion Ignition by Patch
April 23, 2024 at 2:16 pm
Ren
- Is the pipe open-ended on both sides, or closed at one end and which end?
- If detonation is expected, I suggest you use the density-based solver (DBNS). The pressure-based solver (PBNS) should also work if the Mach numebr does not go very high.
- I suggest you use the "Finite-Rate/No TCI" option.
- Are you using a 1-step reaction scheme or multiple reaction scheme. For 1-step reaction, you need to patch a temperature and the composition that correspond to the burnt state of the mixture.
- The mesh needs to be sufficient fine around the flame front (and also shock wave). You can use automatic mesh refinement/coarsening
- The time step size also needs to be much smaller because everything goes very fast. I think 0.005 s is too large. It needs to be around 1E-5 s, or even smaller.
