3D Design
3D Design
Dimensioning large assemblies is too slow
    • ventura
      The problem is when you move the cursor after the first click during dimensioning, when you move the cursor or zoom out it slow down and is impossible to work with.
      Seems the problem is about dynamic dimension showering. Is there a way to avoid that? What solution we have? It's strange SpaceClaim is so slow either with a RTX 4090 and I9 CPU... I saw someone complain this, but I experienced this behavior so many times I expected a solution on your forum, but not.
    • Atharv Joshi
      Hi Ventura,
      Let me check the video and I will get back to you.
      Thanks and Regards
      Atharv
    • Atharv Joshi
      Hi Ventura,
      It could be beneficial to reset the user settings from SpaceClaim Options > Advanced > Reset All User Settings.
      Make sure the graphics card drivers are up to date.
      Go directly to the card manufacturer's website to check for the latest version.
      Aside from that, the card itself may have some settings that you can adjust.  For an NVIDIA card, there is the NVIDIA Control Panel.
      You can access that by right clicking on the main desktop background.  Make sure the default setting is to use the high performance graphics processor.
      Thanks and Regards
      Atharv
      • ventura
        Hello Atharv Joshi,
        I already tried to reset all settings, updated GPU, set default to all NVIDIA settings. But I also tried it in several PC with high end GPU.
        Have you tried to detail some big assembly (around 100Mb)? I saw this behavior several times on some assembly.
        Can I send you my customer's project?
    • Atharv Joshi
      Sure, that will be great.
      Could you please share the file on the same secure link?
      Thanks and Regards
      Atharv
      • ventura
        just sent it
    • ventura
      Please, can you answer and solve? I sent you the file 20 days ago.
    • Atharv Joshi
      Checking with development on the issue. Will update you shortly.
Viewing 5 reply threads
  • The topic ‘Dimensioning large assemblies is too slow’ is closed to new replies.
