Plot Mach Number Contours
    • jainanup27
      Does anyone know hoe to plot the Mach Number Contor when using Pressure Based Solver? The ANYS Help provides the following image
      However, there is  no such option of Mach Number available within the tab
      Thanks,
      Anup
      I'm guessing that air density is constant. Mach Number is available for compressible materials. Otherwise use a Custom Field Function and divide velocity by the speed of sound to show Mach Number for your system.
    • jainanup27
      Density is approximately constant (Incompressible ideal gas) Where can I find custom field function?
      Thanks,
      Anup
      Under the User Defined tab.
      • cfdasdf
        What if I am using Ideal-gas model and still the Mach Number does not appear in CFD-Post? (Mach number is also checked in the Data File Quantities Option)
  • The topic ‘Plot Mach Number Contours’ is closed to new replies.
