Electronics
Electronics
How do I install HFSS?
    • Chris.Lyons
    • Praneeth Munaga
      Hi Chris,
      Please let us know if your question is about installing the software in general or facing any issues during the installation to help us serve you better.
      Best regards,
      Praneeth.
    • Chris.Lyons
      Analog Devices has multiple licenses for HFSS and I simply want to install the Electronics package primarily for HFSS.  I keep accidently downloading Discovery instead.  I also see all this stuff about student versions, which I'm not interesed in.  After logging into the portal how can I get diresctly to the HFSS installation?
    • Praneeth Munaga
      Hi Chris,
      Thanks for your reply. Your patience is much appreciated.
      Please note that you need to download "Electronics" under primary packages for installing the Ansys Electronics Desktop which contains the HFSS bundle along with other Electronics Design types. HFSS is not available as a standalone product for installation.
      Hope this helps.
      Best regards,
      Praneeth.
  • The topic ‘How do I install HFSS?’ is closed to new replies.
