TAGGED: ansys-aqwa, ansysaqwa, aqwa-errors, hydrodynamic-response
March 28, 2024 at 1:21 am
rx20729
SubscriberHi,
I am trying to run some stability analysis within Ansys Hydrodynamic Response on a vessel that I have modelled. However, I am running into the following error:
The model is made up of three interacting structures and I am also using some non-linear catenary mooring lines that are connected between connection points on the structures and fixed points on the seabed. The error does not occur when I run stability analysis on the main vessel, however, when I add the other two structures and the mooring lines to the model, I receive this error message and also the whole structure moves significantly.
Any ideas as to what could be causing this error message will be greatly appreciated.
Thank you.
March 28, 2024 at 1:50 pm
Shuangxing Du
Ansys Employee-
March 28, 2024 at 6:41 pm
rx20729
SubscriberHi,
Thank you for your reply.
I have tried this and I am still getting the error.
I have also manually defined the movement limitations per iteration and the error is still occuring.
April 2, 2024 at 8:29 am
Shuangxing Du
Ansys EmployeeCan you please show your model?
- The topic ‘Aqwa Hydrodynamic Response Error’ is closed to new replies.
6450
