March 27, 2024 at 2:51 pm
Raditya Sebastian
Subscriberim trying to simulate a microcantilever,my goal is to get maximum value of total deformation around 10 or 40 micrometer,however i ran to some problem, the modal analysis gave me this
any help for a way to fixing the maximum value of the total deformation would be greatly appriciated, Thank you in advance
April 5, 2024 at 9:55 am
Aniket
Forum ModeratorPlease check:
/courses/index.php/courses/modal-analysis-in-ansys-mechanical/
/courses/index.php/courses/cantilever-beam-modal-analysis/It's also important to note that the deformation values obtained from a modal analysis are not scaled to any particular force level; they are normalized and typically used to understand the deformation patterns. If you are looking to obtain deformation values under specific loading conditions, you might need to perform a static structural analysis or a prestressed modal analysis where the effects of certain loads are considered.
-Aniket
- The topic ‘Problem with modal analysis in ansys workbench’ is closed to new replies.
3892
1414
1241
1118
1015
