June 10, 2019 at 4:01 pm
Abdoon075
SubscriberHow to model this residual stress in a plate ??
June 11, 2019 at 5:40 pm
June 11, 2019 at 7:31 pm
Abdoon075
SubscriberI can get the help from anyone has the full version of ANSYS , But I need to know to model these type of stresses
please help me
June 12, 2019 at 1:25 am
peteroznewman
SubscriberAre you trying to reproduce a result from a research paper? What is the title of the paper?
June 13, 2019 at 1:29 pm
Abdoon075
Subscriberthe paper title is " Propagation rate of large cracks in stiffened panels under tension loading " , you can find the talk about residual stress modeling in page 18
June 13, 2019 at 2:29 pm
peteroznewman
SubscriberAnsys has an INISTATE command that applies an initial stress to elements in the model at the start of the simulation. This is how you could apply a residual stress.
June 13, 2019 at 3:33 pm
Abdoon075
SubscriberCan I apply the stress as a function of plate width ??
June 13, 2019 at 3:40 pm
peteroznewman
SubscriberYou can apply any stress you want to any element. You have complete control to do whatever you want and you know the plate width.
Note that this is applying an initial stress to elements before the solver starts, while other elements have zero stress before the solver starts. You have to run the solver and allow equilibrium to occur before you would have the body in a state you could call residual stress, after equilibrium has been achieved by the solver converging on a solution.
June 15, 2019 at 12:03 am
Abdoon075
SubscriberI found that command in APDL , But I can't find it in ANSYS Mechanical Enterprise
June 15, 2019 at 12:08 am
peteroznewman
SubscriberYou insert a command object to use APDL commands in the Mechanical Workbench environment. Here is an example.
- The topic ‘Residual stress’ is closed to new replies.
6475
