Photonics – Chinese
Photonics – Chinese
FDTD腳本問題
    • 謝 郁弘
      我想要詢問一下我想用腳本調整set simulation bandwidth,但是用腳本調整min和max的波長時卻找不到property,這是因為甚麼問題。
      https://drive.google.com/file/d/14pgYytQ5YiJTpGZIgXdz25kxZZE5Nj_d/view?usp=drive_link
      https://drive.google.com/file/d/1T5UHfC6F2b1VSuS2NVuX0u0IWxULpoUd/view?usp=drive_link
    • Guilin Sun
      那是因为名字不对,参考这个
      你不要用Select因为前面已经选中FDTD了。
      要想知道有什么名称,可以用
      ?setnamed("FDTD")
      就可以在Prompt那里显示所有此物体FDTD的变量名字:
       ?setnamed("FDTD");
      allow grading in x
      allow grading in y
      allow grading in z
      allow symmetry on all boundaries
      always use complex fields
      angle phi
      angle theta
      auto scale pml parameters
      auto shutoff max
      auto shutoff min
      background material
      bfast alpha
      bfast dt multiplier
      bloch units
      checkpoint at shutoff
      checkpoint during simulation
      checkpoint period
      conformal meshing refinement
      define x mesh by
      define y mesh by
      define z mesh by
      dimension
      direction
      down sample time
      dt
      dt stability factor
      dx
      dy
      dz
      enabled
      express mode
      extend structure through pml
      force symmetric x mesh
      force symmetric y mesh
      force symmetric z mesh
      global monitor custom frequency samples
      global monitor frequency center
      global monitor frequency points
      global monitor frequency span
      global monitor maximum frequency
      global monitor maximum wavelength
      global monitor minimum frequency
      global monitor minimum wavelength
      global monitor sample spacing
      global monitor use source limits
      global monitor use wavelength spacing
      global monitor wavelength center
      global monitor wavelength span
      global source bandwidth
      global source center frequency
      global source center wavelength
      global source eliminate discontinuities
      global source frequency
      global source frequency span
      global source frequency start
      global source frequency stop
      global source offset
      global source optimize for short pulse
      global source pulse type
      global source pulselength
      global source set frequency
      global source set time domain
      global source set wavelength
      global source wavelength span
      global source wavelength start
      global source wavelength stop
      grading factor
      index
      injection axis
      kx
      ky
      kz
      max source time signal length
      mesh accuracy
      mesh allowed size increase factor
      mesh cells per wavelength
      mesh cells x
      mesh cells y
      mesh cells z
      mesh distance between fixed points
      mesh frequency max
      mesh frequency min
      mesh merge distance
      mesh minimum neighbor size
      mesh refinement
      mesh size reduction factor
      mesh step for metals
      mesh type
      mesh wavelength max
      mesh wavelength min
      meshing refinement
      meshing tolerance
      min mesh step
      name
      nx
      ny
      nz
      override simulation bandwidth for mesh generation
      param1
      param2
      pml alpha
      pml alpha polynomial
      pml kappa
      pml layers
      pml max layers
      pml min layers
      pml polynomial
      pml profile
      pml sigma
      pml type
      same settings on all boundaries
      set based on source angle
      set process grid
      simulation frequency max
      simulation frequency min
      simulation temperature
      simulation time
      simulation wavelength max
      simulation wavelength min
      snap pec to yee cell boundary
      source index
      type
      use auto shutoff
      use bfast fdtd
      use divergence checking
      use early shutoff
      use legacy conformal interface detection
      use mesh step for metals
      use relative coordinates
      x
      x max
      x max bc
      x min
      x min bc
      x span
      y
      y max
      y max bc
      y min
      y min bc
      y span
      z
      z max
      z max bc
      z min
      z min bc
      z span
      其它物体也可以用此法找。
  • The topic ‘FDTD腳本問題’ is closed to new replies.
