Electronics
Electronics
Assigning Phase excitation
    • Aabhishek Naicker
       Excitation 'PhA_0' and Excitation 'A_1' overlap.
      Warning - Excitation 'PhA_1' and Excitation 'A_2' overlap.
      When I tried to assign phase excitation for an IPM motor this error showed up. Even after selecting the predefined phase coil this warning message popped up.
    • GLUO
      This means there are multiple squre coil objects overlapping at the same location. Please double check if all your coils are not duplicated. You can do this by select them in the model window and then hide them to see if there is another coil behind them.
      GL
  • The topic ‘Assigning Phase excitation’ is closed to new replies.
