Ansys Learning Forum Forums Discuss Simulation General Mechanical Difference in force-deflection curve (Remote displacement vs Loading Plate) Reply To: Difference in force-deflection curve (Remote displacement vs Loading Plate)
ErKo
Hi
See if this tutorial (link below) helps. So just use a displacement with y non zero and x and z free on an edge – so do not use a remote displacement with all zero except of y of course. The tutorial also shows how to extract the failure load (force reaction of imposed displacement).
As for why you get different values, could be many things (material properties etc.) . In theory it could be able to capture the failure of a RC beam.
Some test cases where it has been used: https://www.researchgate.net/publication/354765497_Calibration_and_Validation_of_the_Menetrey-Willam_Constitutive_Model_for_Concrete.
/forum/forums/topic/how-can-we-model-failure-in-reinforced-concrete-rc-slabs/
All the best
Erik
