Ansys Products
Ansys Products
Invalid LSDYNA keyword file format: Ls Dyna
    • king79
      I recently started having problems opening files with LsPrePost. After creating a new LsDyna model and saving it, when I attempt to open it, I get the following error message: Invalid LSDYNA keyword file format.
      When I try to run the file, it terminates without any explanation. Can you please provide assistance or suggestions?
      Thank you
    • Ram Gopisetti
      Hi King79,
      Please check your input file for corrupted lines, LSDYNA needs its input file in a format aligned to the left or separated by a comma, in the latest versions of LSPP, it will let you know where the file is corrupted or missing the format.
      Please check the d3hsp and/or messxxx files for potential error messages and make the needed changes in your input file.
      Cheers, Ram
    • king79
      Thanks for your response. The error message was due to limited storage space for LS-run to complete the analysis.
  • The topic ‘Invalid LSDYNA keyword file format: Ls Dyna’ is closed to new replies.
