Determine the area of a region with stress greater than the predetermined value
    • dinhan0394
      Hi everyone,
      After completing the solution, I can exploit the results on the body.
      But how can I determine the area of a region with stress (or any result) greater than the predetermined value?
      For example, the figure below is the stress result of one face, I want to calculate the area of the region with stress greater than 80MPa.
      Is this possible?
      Thank you.
    • Yato
      To visualize the area greater or less than a result, you must activate the capped isosurface option. I attach images.
    • dinhan0394
      Thank you for your help.
      But that way only visualize the region greater or less than a result, can not get area value of it. I want to get area value.
      Ex, original surface have area = 100m2. On it, 1/4 region have stress greater than 100 --> the value I get = 100/4=25m2
    • jj77
      See engtips fea AnPham - this is the best I can come up with and absolutely valid from an FEA point of view (so edit:thin membrane shells are often used to get better surface stresses on 3D parts, made of bricks)
  • The topic ‘Determine the area of a region with stress greater than the predetermined value’ is closed to new replies.
