May 26, 2019 at 3:15 pm
saadalam
SubscriberI am having confusion how to apply correct boundary conditions in a green-house chamber covered with poly-ethane sheet which is inside another chamber which is also covered with poly-ethane sheet.
This chamber is subjected to sunlight (solar radiation) and air at ambient conditions.
I am attaching image of CAD Model for reference.
Please help.!
May 27, 2019 at 4:53 am
Amine Ben Hadj Ali
Ansys EmployeePlease insert pictures here and add why are you confused. -
June 6, 2019 at 3:31 pm
saadalam
Very sorry for late reply and thanks for your time and attention.
I am especially confused of BC on Polyethylene Sheet shown in Yellow Color (i.e. which is covering the Primary Chamber) which has air at ambient conditions on both side (i.e. outside and inside)
June 6, 2019 at 4:27 pm
Forum ModeratorWhat's confusing about it? Which solver do you want to use?
June 6, 2019 at 4:44 pm
Amine Ben Hadj Ali
Ansys EmployeeSemi transparent? -
June 6, 2019 at 5:15 pm
saadalam
SubscriberYes Semi transparent -
June 6, 2019 at 5:16 pm
saadalam
SubscriberFluent
I am especially confused of BC on Polyethylene Sheet shown in Yellow Color (i.e. which is covering the Primary Chamber) which has air at ambient conditions on both side (i.e. outside and inside) -
June 7, 2019 at 10:39 am
Forum ModeratorYes, that's a possible using a wall condition. If you want light to pass through it turn on shell conduction and semi-transparent. The former is to force the solver to use the material radiation properties. Â
June 7, 2019 at 11:12 am
saadalam
Subscriber@rwoolhou.
I got your point but there is a problem.
Since i have 2 fluid domains representing Primary and secondary chambers, So I have their walls like stick to each other (As shown in attached Image).
Kindly tell me this also, Should I apply same "Semi transparent Wall conditions"Â on both or any one wall is enough??
- The topic ‘Greenhouse Chamber inside another Greenhouse chamber’ is closed to new replies.
4838
1587
1386
1242
