Electronics
Electronics
E field written to a register file is empty
    • coleen.dizon
      I am trying to export the E-field quantity of a simulation by writing it to a .reg file. However, after checking the file, it shows that the elements are empty. Why does this happen and how can I make it not empty?
    • Reshmi Raghavan
      Hello Coleen,
      You can export out the E field values from Maxwell in the form of a .fld file. You can make use of the field calculator for the same. Please follow the below steps to extract the same.
      Open field calcualtor
      Input> Quantity >E
      Input>Geometry>Select the goemetry where the field has to be exported
      Output>Value
      Output >Write >Sale the .fld file
      The saved fld file can be imported into an excel for further postprocessing.
    • coleen.dizon
      Hi Reshmi,
      I tried writing the fields quantity to a .fld file. When I imported it in excel, it also showed empty elements. Though when I also put the geometry before saving to a file, it gives me a value.
  • The topic ‘E field written to a register file is empty’ is closed to new replies.
