Ansys Learning Forum Forums Discuss Simulation General Mechanical Update failed for the Solution component in Fluent. Update Solution Failed Reply To: Update failed for the Solution component in Fluent. Update Solution Failed
Young Duk Lee
when i load the case and data file to the fluent tab, should i click the yes about the data interpolation  option?  if it is,, then how do i next step?
