Ansys Learning Forum Forums Discuss Simulation General Mechanical Update failed for the Solution component in Fluent. Update Solution Failed Reply To: Update failed for the Solution component in Fluent. Update Solution Failed
Young Duk Lee
Here is the images,,,,,,,,,,,,,  first, when i input the case and data file to the fluent, i choosed the yes(below image)
and then, this is image you want
