February 29, 2024 at 4:01 pm
Mustafa Celik
SubscriberHello,
I'm getting a license error just right after installation. I tried to re-install with admin rights, even ran licensing client apps underÂ
C:\Program Files\AnsysEM\Ansys Student\v232\Win64\licensingclient\winx64
but no luck. LMUTIL also can't find the license file by default:
lmutil - Copyright (c) 1989-2022 Flexera. All Rights Reserved.
Flexible License Manager status on Thu 2/29/2024 10:58[Detecting lmgrd processes...]
Error getting status: Cannot find license file. (-1,359:2 "No such file or directory")Would you please help me locating the license?
Thanks
$begin 'General Info'ProductName='Ansys® Electromagnetics Student 'BuildInfo='Release 2023 R2 (Build: 2023-05-16 22:25:19)'ExeInfo='Executing from C:\\Program Files\\AnsysEM\\Ansys Student\\v232\\Win64\\ansysedtsv.exe'$end 'General Info'Â$begin 'Installed Components'$end 'Installed Components'Â$begin 'License Info'FlexlmVersion='2023.0505'AdminDir=''CustomerNumber='-1'LicenseFiles('\\ansyslmd.ini')ActiveServers()ActiveHostIds()Provider='Ansys Common Licensing''ANSYSLI Version'='2023.1.0'$end 'License Info'Â
March 1, 2024 at 11:21 am
Mrunali Barde
Ansys EmployeeÂ
Hello Mustafa,Â
I assume you have not installed the student version, have you downloaded the academic version before this?
You need not install server details for the students' version.
Which version of the Ansys application have you installed? Do you have academic or commercial licenses?Wishes,Â
Mrunali.Â
March 2, 2024 at 2:10 am
Mustafa Celik
SubscriberHello Mrunali,
Thanks for the reply but I do have the student version of the software. I did not have any other versions.
For the student version, I have installed it and then I couldn't start the application due to the error above.
I would appreciate any other suggestions.
March 4, 2024 at 1:15 pm
Rajeshwari Jadhav
Forum ModeratorHi Mustafa,
Please delete the ansyslmd.ini file (C:\Program Files\ANSYS Inc\ANSYS Student\Shared Files\licensing) and Ansoft folder (Documents).Â
Try to relaunch the application.
March 4, 2024 at 10:33 pm
Mustafa Celik
SubscriberHello,
Thanks for the reply. I couldn't find ansyslmd.ini under Documents/Ansoft folder but there is one under "C:\Program Files\AnsysEM\Shared Files\Licensing" which is an empty file.
I was able to start the software by re-downloading, re-installing it (without deleting old one) and using the modify option. I tried repair option before which didn't fix. Hopefully, this helps some other people if they face similar issue.
March 5, 2024 at 9:23 am
Mrunali Barde
Ansys EmployeeThank you for the update Mustafa,Â
For future reference: ansyslmd.ini file is under  "C:\Program Files\AnsysEM\Shared Files\Licensing".
Renaming Documents\Ansoft to Ansoft.old will clear the cache.Â
I'm glad that the issue is issue is resolved.Â
- The topic ‘Need help with License Error – Ansys Electronics Desktop Student’ is closed to new replies.
