ANSYS Watertight Geometry Workflow
    • Adam Thibodeaux
      Hello, I am new to ANSYS and am drawing my first 3D geometry and am having trouble meshing it. My goal is to model flow around storage tanks (similar to those in the industry) to visualize how the wind will flow around them. When trying to create the mesh, I keep getting an error message that prevent me from moving on. I have watched several YouTube videos that are similar and none of them get this error message. Do you have any Ideas?
      I appreciate any help you can provide!
      Adam
    • Keyur Kanade
      Make sure your geometry has closed region. i.e. make sure you have a solid body in SpaceClaim.
      Please check geometry in SpaceClaim.
      Select geometry in structure tree --> Use right click --> Select Check Geometry. (Or Tools - Fault Detection in DM)
      The geometry should be error free to proceed.
      If geometry has any errors, please modify/recreate geometry at those places.
      For meshing make sure you apply correct sizing.
      Please go through help manual for more details
      Please check following videos
      Ansys Meshing Sizing:
      https://www.youtube.com/watch?v=w4q6q8nKF3U
      Fluent Meshing Watertight Workflow:
      https://www.youtube.com/watch?v=aBxbYRVoRLo
      Keyur
      Fluids Engineering Courses | Ansys Innovation Courses
    • Adam Thibodeaux
      Good Morning Keyur!
      Thank you for sending the videos and documents. I have watched them and tried to adjust the main settings similar to the "Fluent Meshing Watertight Workflow" video and only adjusted my mesh min and max to 60 and 120 in, respectively. However, I am still getting the same error. On the left side of the screen, the workflow has all green checkboxes up to the "Describe Geometry" task. Do you think this is a setting or a software issue? I was thinking it was a setting since this is my first time using it, but I am unable to generate it after using some of the same settings from the video. Do you know of any software tutors that I could reach out to and see what I am doing wrong?
      Thank You!
      Adam
    • Keyur Kanade
      Keyur
    • Adam Thibodeaux
      Thank Keyur for the response. I checked the geometry and it stated no errors in the popup at the bottom of the screen. I can send a picture of when I get to my computer.
      Thank You!
      Adam
    • Adam Thibodeaux
      Good Evening Keyur -
      This is the pop-up I get when I check the geometry. It states "No geometry problems were found". I also attached the settings I have been using to generate the mesh.
      Do you see any mistakes that I am making? Please let me know anything else I can try.
      Thank You!
      Adam
    • Keyur Kanade
      It looks mulit body compoenent. Have you used Share option under Workbench tab? You will need to use this option to get conformal mesh. Please go through help manual for more details
      DM Share topology:
      https://www.youtube.com/watch?v=IO4ZtwZdD2I
      SpaceClaim Share topology:
      https://www.youtube.com/watch?v=h43E1YO1LiM
      Keyur
    • Adam Thibodeaux
      Good Afternoon Keyur -
      Sorry for getting back with you so late, I had something come up. I applied shared topology and it seemed to have worked! Thank you so much for helping me!! I would have never tried adjusting topology as I am still learning the software.
      Thank you!
      Adam
Viewing 7 reply threads
  • The topic ‘ANSYS Watertight Geometry Workflow’ is closed to new replies.
