February 8, 2024 at 7:51 pm
Saeed
SubscriberHello,
I want know if it is possible to do ANSYS fluent - Rocky DEM coupling with HPC ?
February 9, 2024 at 9:55 am
Forum ModeratorIt is. However, you need to exercise some care in how you use the nodes and set up the coupling. Please provide more details on your cluster, but also check that you can manually check and assign where jobs go.
February 9, 2024 at 3:31 pm
Saeed
SubscriberThank you for your answer, our HPC cluster currently comprises over 23,000 cores, spread among 400 nodes, with two CPUs per node.
Also, I want use dynamic mesh for my simulation, is rocky Comaptible with dynamic mesh ?
Thanks
February 9, 2024 at 3:43 pm
Forum ModeratorThe compatability will be covered in the documentation. Sliding mesh is fine, but remeshing may cause problems. https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v241/en/dem_cfd_coupling/section-limitations-twoway.html
If you can specify which cores you use rather than launching into a blind queue you should be OK. If you don't know where the processes are you may have a problem as Rocky needs to know where the Fluent process is.
March 6, 2024 at 9:15 pm
Saeed
Subscriberour HPC members tried to install rocky on our hpc on fot the following error. can you please help us with it:
It looks like Rocky will not work with 2023R2 nor 2024R1 due to our Red Hat 8.8 Operating System glibc version:
Rocky Traceback (most recent call last): File "/home/jenkins/Work/miniconda/
envs/_rocky30-freeze-linux64- py36-v3/lib/python3.6/site- packages/cx_Freeze/ initscripts/__startup__.py", line 14, in run File "/home/jenkins/Work/miniconda/ envs/_rocky30-freeze-linux64- py36-v3/lib/python3.6/site- packages/cx_Freeze/ initscripts/Console.py", line 26, in run File "/home/jenkins/Work/Jenkins/ workspace/rocky30-rb-ROCKY- v23.2.0-ansys-newlinux/ rocky30/source/python/main.py" , line 13, in File "/home/jenkins/Work/Jenkins/ workspace/rocky30-rb-ROCKY- v23.2.0-ansys-newlinux/ rocky30/source/python/rocky30/ frozen_utils.py", line 70, in RockyBasedAppMain File "/home/jenkins/Work/Jenkins/ workspace/rocky30-rb-ROCKY- v23.2.0-ansys-newlinux/etk/ plugins10/source/python/ plugins10/plugins/basic_ application/main.py", line 264, in Main File "/home/jenkins/Work/Jenkins/ workspace/rocky30-rb-ROCKY- v23.2.0-ansys-newlinux/etk/ plugins10/source/python/ plugins10/plugins/basic_ application/main.py", line 415, in _Main File "/home/jenkins/Work/Jenkins/ workspace/rocky30-rb-ROCKY- v23.2.0-ansys-newlinux/ rocky30/source/python/rocky30/ rocky_application_setup.py", line 63, in RegisterPlugins File "/home/jenkins/Work/Jenkins/ workspace/rocky30-rb-ROCKY- v23.2.0-ansys-newlinux/ rocky30/source/python/rocky30/ rocky_application_setup.py", line 111, in RegisterPlugins File "/home/jenkins/Work/Jenkins/ workspace/rocky30-rb-ROCKY- v23.2.0-ansys-newlinux/ rocky30/source/python/rocky30/ plugin_registry.py", line 170, in register_plugins File "/home/jenkins/Work/Jenkins/ workspace/rocky30-rb-ROCKY- v23.2.0-ansys-newlinux/ kraken20/source/python/ kraken20/main.py", line 78, in ImportQWebEngineModules File "/home/jenkins/Work/Jenkins/ workspace/rocky30-rb-ROCKY- v23.2.0-ansys-newlinux/ rocky30/source/python/rocky30/ _cx_freeze_vtk9_hack.py", line 18, in import_hook_wrapper File "ExtensionLoader_PyQt5_ QtWebEngineWidgets.py", line 22, in File "ExtensionLoader_PyQt5_ QtWebEngineWidgets.py", line 14, in __bootstrap__ File "/home/jenkins/Work/miniconda/ envs/_rocky30-freeze-linux64- py36-v3/lib/python3.6/imp.py", line 343, in load_dynamic ImportError: /gpfs/sharedfs1/admin/hpc2.0/ apps/ansys/2023R2/v232/ Electronics/Linux64/libstdc++. so.6: version `GLIBCXX_3.4.26' not found (required by /gpfs/sharedfs1/admin/hpc2.0/ apps/ansys/2023R2/v232/rocky/ bin/lib/python3.6/../../ libQt5WebEngineCore.so.5) Both Rocky versions are looking for
GLIBCXX_3.4.26, but unfortunately we only have up toGLIBCXX_3.4.25' with our current glibc system version installed on our systems.
- The topic ‘ANSYS fluent – Rocky DEM coupling’ is closed to new replies.
6470
