Ansys Learning Forum Forums Discuss Simulation Fluids Low heat generation due to thermal runaway reactions when adding combustion Reply To: Low heat generation due to thermal runaway reactions when adding combustion
Murari Iyengar
Hi, the two models you are using are incompatible with each other.
