April 26, 2019 at 11:32 am
Matt17
SubscriberI am receiving the following error when tryig to solve my structural analysis with APDL:
"element 148645 requires material properties and references material number 0 for which no properties are defined. Checking terminates."
I have no Material 0 defined and have assigned my materials according to specific components using the component manager.Â
Any advice appreciated. -
April 26, 2019 at 12:18 pm
jj77
SubscriberSelect that element or just see what is the MAT assignment for the element, is it 0 or ?
Just use ELIST,148645 and see what MAT, TYPE, REAL are
April 26, 2019 at 2:05 pm
Matt17
SubscriberHi,Â
After using ELIST the following returned:
LIST ALL SELECTED ELEMENTS IN RANGEÂ Â 148645Â TOÂ Â 148645Â STEPÂ Â Â Â 1
 *** ANSYS - ENGINEERING ANALYSIS SYSTEM RELEASE Release 18.2   18.2   ***
 ANSYS Academic Teaching Advanced         Â
 00246256 VERSION=WINDOWS x64  14:19:47 APR 26, 2019 CP=   4.696
  ELEM MAT TYP REL ESY SEC    NODES
 148645  0  0  0  0  0  132212 132254 132290
I have used component manager to assign material attributes to each component. As far as I can see there is no area that I haven't assigned to a component. Also the Material Models I have range from 1-3 so 0 shouldn't be possible? I am reassigning all my components so hopefully I will find the error here.
This is a different issue also, but IÂ am finding that APDL crashes occassionally when I move the model? I have attached a screenshot of the warning that appears when this happens.
April 26, 2019 at 2:45 pm
jj77
SubscriberThe screenshot shows some form of issue so I would escalate that to Ansys - send it to their support. Sure the Ansys guys here in the forum can give some more directions on how to report this - all software vendors should be very glad to get these things reported and sorted as it makes the software more reliable
April 26, 2019 at 2:52 pm
April 26, 2019 at 2:55 pm
April 27, 2019 at 3:05 am
Sandeep Medikonda
Ansys EmployeeAre you using super elements? might be looking for a file.
If not, Can you try upgrading to 2019R1 and see if it helps?
- The topic ‘Why is APDL saying some of my elements do not have material properties?’ is closed to new replies.
5844
1305
