January 16, 2024 at 3:40 am
Dato
SubscriberHi,
I want to use "merge" to merge inside faces together. It performs successfully but it causes my geometry distortion. The geometry that before performing "merge" is showing below.
After perfoming "merge", it becomes like that. As you can see, the curves are greatly changed.
And the settings are showing below.
I want to know why and how can I merge the surfaces? Welcome to discuss together.
January 16, 2024 at 7:04 am
Keyur Kanade
Ansys EmployeeMerging faces at geometry level in DM is not recommended. If these faces are not giving any problem in meshing, you can leave them as they are.
Also if you want to have then single name then please use Named Selection.
Please go through help manual for more details
Keyur
Fluids Engineering Courses | Ansys Innovation Courses
January 16, 2024 at 7:43 am
Dato
SubscriberWhy it's not recommended to merge surfaces in DM? Is it because of the software or I can try merging faces by other software like discovery or spaceclaim?
January 16, 2024 at 8:23 am
Keyur Kanade
Ansys EmployeeWhy do you want to merge these faces?
January 17, 2024 at 7:46 am
Dato
SubscriberOh, I got you. Thank you so much????
- The topic ‘geometry distortion using “merge” in Design Modeler’ is closed to new replies.
3632
1313
1142
1068
1008
