Ansys Products
Ansys Products
GPU acceleration in Ansys Mechanical
    • Moritz Baierl
      Hi guys,
      I´m currently working with Mechanical on my workstation with an Nvidia RTX A2000 GPU. Unfortunately this model isn`t supported with the 2022R2 Release. Is there any way that I could use it tough?
      Instructions how to set it up or any other help would be great.
      Thanks, Moritz
    • Aniket Chavan
      Please refer to Gary's answer on /forum/forums/topic/how-to-enable-gpu-acceleration-properly-on-ansys-mechanical-enterprise/. -Aniket Forum Rules & Guidelines
    • Moritz Baierl
      Hello Aniket,
      I tried to set this variable but now I am getting a licensing error:
      The ANSYS Helpguide writes that it might be possible that a GPU acceleration is not possible if RSM is installed as a service. I have RSM installed, might this be the problem for the licensing error?
    • George Karnos
      How many Cores are you asking for as well as using GPU?
      How many HPC Licenses do you have ( What licenses are listed from a license status?)
      If you open a dos command prompt and type in the following:
      set
      Then hit Enter.
      What is the entire output from that?
      Also, under %TEMP%\.ansys You will see .out files and a log file:
      ansyscl.hostname.log
      Are any other errors listed in those files?
  • The topic ‘GPU acceleration in Ansys Mechanical’ is closed to new replies.
