January 4, 2024 at 12:11 am
Mauricio Casarotto
SubscriberI have the following script to model and study an isotropic hardening model:
---------------------------------------------------------------------------------------------------FINISH/CLEAR!Asignando nombres al analisis/FILNAME,viga-ep-script,1/Title,Analisis-ElastoPlastico!Definiendo unidades (m,kg,s,K)/UNITS,SI!Entrando al preprocesador/PREP7!Definiendo tipo de análisisANTYPE,STATIC,NEW!Definiendo propiedades del materialMAT,1MP,EX,1,2E11MP,PRXY,1,0.3TB,BISO,1TBDATA,1,4E8,1E9!Definiendo keypointsK,1,0,0,0K,2,0.003,0,0K,3,0.003,0.001,0K,4,0,0.001,0!Definiendo lineasLSTR,1,2LSTR,2,3LSTR,3,4LSTR,4,1!Definiendo areaA,1,2,3,4!Definiendo nodosNKPT,1,1NKPT,13,2NKPT,65,3NKPT,53,4FILL,1,13FILL,13,65,3,26,13FILL,1,53,3,14,13FILL,14,26FILL,27,39FILL,40,52FILL,53,65!Definiendo elementoET,1,PLANE182,0,,2,,,1!Asignando malla al areaAATT,1,,,,1!Estableciendo la mallaMSHAPE,0,2DMSHKEY,0LESIZE,1,,,12LESIZE,2,,,4LESIZE,3,,,12LESIZE,4,,,4AMESH,ALLNUMMRG,NODE!Estableciendo las cargas y restriccionesD,1,ALL,0D,14,UX,0,,53,13D,65,UX,0D,65,UY,-0.001!Iniciando el solucionador/SOLU!Incluyendo no linealidadesNLGEOM,ONAUTOTS,OFFDELTIM,1NSUBST,80KBC,0!SolucionandoOUTRES,ALL,ALL,,,,SOLVEFINISH/POST1SET,LAST,80PLDISP,1PLNSOL,S,EQV,0PLNSOL,EPPL,EQV,0,,,,AUTOPLNSOL,EPTO,EQV,0,,,,AUTO/POST26!Curva U-LNUMVAR,200TIMERANGE,0,1NSOL,2,65,U,Y,DESPLAZAMIENTOXVAR,2ABS,2,2,,,DESPLA,,,1PLTIME,0,1ESOL,3,48,65,F,Y,CARGA/AXLAB,X,DISPLACEMENT/AXLAB,Y,LOADPLVAR,3---------------------------------------------------------------------------------------------------While the deformed shape is right and compares to the ones in previous studies, when I graph the load vs displacement I get the right numbers but a thousand times bigger than the previous studies. The values of forces should be in the range of 60 to 65.I dont know what am I doing wrong. -
January 4, 2024 at 2:21 pm
Chandra Sekaran
Ansys EmployeeMy guess is that it must be something inconsistent with the units. Can you add units as comments to the input deck? What is the reference you are comparing to?
January 5, 2024 at 2:26 pm
Mauricio Casarotto
SubscriberI tried commenting the /UNITS command, but the output was the same. Here you can find the reference A comparison of triangle and quadrangle finite elements for large strain elastoplastic formulations
- The topic ‘Magnitude error’ is closed to new replies.
1494
1386
1209
