January 3, 2024 at 12:35 pm
Amar Cindrak
SubscriberHello,Â
What is the "physical" difference between joint and pretension when applying a bolt pretension load ?Â
When should joint be applied and when should pretension be applied ?Â
I ask that because I don't get the same value of stress locally at the bot's thread when using "joint" and when using "pretension", although the same bolt pretension value has been applied.Â
Best regards,
AmarÂ
January 4, 2024 at 10:28 am
Akshay Maniyar
Ansys EmployeeHi Amar,
 If the bolt specified with pretension is likely to undergo large rotation, set this property to Joint. Please check the below Ansys help link for more details.
3.9. Defining Preload in a Joint Fastener Undergoing Large Rotation (ansys.com)
Thanks,
Akshay Maniyar
- The topic ‘Difference between Joint and Pretension ?’ is closed to new replies.
Ansys Innovation Space
897
599
591
444
