inlet velocity varying in space and time
    • smfr
      how to prescribe an inlet velocity varying in space and time in Fluent?
      any references?
      Many thanks
    • Keyur Kanade
      you can use udf.
      check following tutorial which has time varying udf.
      https://confluence.cornell.edu/display/SIMULATION/FLUENT+-+3D+Bifurcating+Artery
    • smfr
      thanks for your reply
      Actually I have got variation in both space and time
      Any suggestions?
    • Karthik Remella
      Administrator
      As mentioned by Keyur, you will need to use a UDF to do this. Please refer to Fluent Customization manual for details. There are numerous examples on how to use UDFs to pass a velocity profile to Fluent. You will need to use DEFINE_PROFILE macro for this. Here is an example from the Customization Manual.
      Thank you.
      Best Regards,
      Karthik
    • smfr
      Very much appreciated
      I'll look at it
      Can you confirm variation in space and variation in time can be combined in a single udf?
      Many thanks
    • Keyur Kanade
      yes, it can be combined in single udf.
Viewing 5 reply threads
  • The topic ‘inlet velocity varying in space and time’ is closed to new replies.
