December 13, 2023 at 3:29 pm
Syed Saif Ali
SubscriberHi Team,
Our customer is having issue with the activation of license using CMD, Can you please assist?
Curl Error (35) SSL connect error - schannel: next InitializeSecurityContext failed: Unknown error (0x80092012) - The revocation function was unable to check revocation for the certificate.
ERROR: Unable to activate entitlement with activation id 'Act-cb83293b-61df-4043-814b-c7cff9b0e995', error:
Also "curl -v --ssl-no-revoke https://laas.fnocc.com is failing" -
December 18, 2023 at 4:53 pm
George Karnos
Ansys EmployeeTry the following:
Must allow connectivity on port 443 to these sites:laas.fnocc.comocsp.digicert.comocsp.int-x3.letsencrypt.orgflex1397.flexnetoperations.comr3.o.lencr.orgRun these commands:curl -v --ssl-no-revoke https://laas.fnocc.comcurl -v https://laas.fnocc.comcheck https://laas.fnocc.com/FNOConnectorCore/ansys/healthcheck through the browserPost any and all errors encountered. -
December 19, 2023 at 2:48 pm
December 19, 2023 at 3:02 pm
George Karnos
Ansys EmployeeCan you have them run the commands and share the output from those commands?
Do they use a proxy?
Install the latest DigiCert certificate: https://discoveryforum.ansys.com/t/h4gzdg
Make sure they have the ISRG ROOT X1 certificate.
December 19, 2023 at 3:15 pm
December 28, 2023 at 5:40 pm
ANSYS_MMadore
Forum ModeratorHello Syed, did you confirm the certificates?
Please send the output of these commands:
curl -v --ssl-no-revoke https://laas.fnocc.comcurl -v https://laas.fnocc.comDid the user test connectivity to the listed sites? You can test these with telnet:telnet SITE 443or using Powershell
Test-NetConnection SITE -Port 443
Does the customer use a proxy for connection to the internet?1. Add ocsp.digicert.com to their firewalls to ensure full connectivity with the site. The appropriate measure is to allow access to the certificate check URL: ocsp.digicert.com. Please have their IT ensure they can connect to the DigiCert revocation server.
2. Have them try installing Digicert as in https://discoveryforum.ansys.com/t/h4gzdg
3. Potentially a Proxy in place. Make sure they set the proxy settings under Internet Options and the HTTPS_PROXY variable. For reference see https://discoveryforum.ansys.com/t/m2jxqa/discovery-patch-for-addressing-proxy-server-issues
Are you able to submit a Support Request on the customer portal where we might be able to dig deeper?
- The topic ‘SpaceClaim License Issue’ is closed to new replies.
6650
1312
