Maximum Load to yield a material in a component
    • Sam Fares
      Is there a way to have Ansys calculate the load required to yield a material in a component?
      Thanks,
      Sam
      Hello Sam,
      Use a linear elastic material: just Young's Modulus and Poisson's Ratio.
      Apply a unit load, F = 1 lbf and solve.
      Insert the Equivalent vonMises Stress result and obtain the maximum Stress, Sm.
      The load Fy required to reach the Yield Stress, Sy is
      Fy = Sy/Sm.
      Since everything is linear, the ratio of forces is equal to the ratio of stress.
      That assumes you have done a Mesh Refinement Study and have converged on the exact maximum stress.
      Regards, Peter
    • sathya
      Hi If you consider nonlinearities in your setup,you have to run for higher load with enough substeps to predict failure.no shortcut.
    • Sam Fares
      Thank you Peter!
    • Sam Fares
      Thank you Sathya
Viewing 4 reply threads
  • The topic ‘Maximum Load to yield a material in a component’ is closed to new replies.
